Salta al contenuto principale
Back Cover Replacement
Desiree DesJardins
Desiree DesJardins e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
This guide is a prerequisite to accessing the inside of the Zoomer Dino Boomer, where the battery, electronics, and pulley system are located. It is important to be gentle while opening the dinosaur since the top covering will still be attached to the electronic system via a wire.
Cosa ti serve
Strumenti
Mostra di più…
  1. Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Back Cover Replacement: passo 2, immagine 1 di 2 Back Cover Replacement: passo 2, immagine 2 di 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Back Cover Replacement: passo 3, immagine 1 di 3 Back Cover Replacement: passo 3, immagine 2 di 3 Back Cover Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
Conclusione
USF Tampa, Team 16-1, Wollert Fall 2015 Membro di USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 779
