Salta al contenuto principale
Baby Taylor Guitar String Replacement
Mohamed Saleh
Mohamed Saleh e un altro collaboratore
Ultimo aggiornamento il December 23, 2021
30 minuti
Moderato
Introduzione
Vai al passo 1
Follow my 9-step fast fix procedure to replace your Baby Taylor Guitar’s strings. Guitar strings become dull-sounding and lose their tone as they age, that’s why it’s important to know how to change your guitar strings at any time. When a string is broken or doesn’t sound as sharp as it used to, this guide will help you fix than in less than 30 minutes.
  1. Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, immagine 1 di 3 Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, immagine 2 di 3 Baby Taylor Guitar String Replacement, Guitar String Replacement: passo 1, immagine 3 di 3
    • Rotate the tuner of the string you want to replace in a clockwise direction until it's loose.
    • You can either do it by hand (First Picture) or you can use the guitar string winder (Second picture).
  2. Baby Taylor Guitar String Replacement: passo 2, immagine 1 di 2 Baby Taylor Guitar String Replacement: passo 2, immagine 2 di 2
    • Grab a plier and pull out the bridge pin of the string you want to replace.
    • Make sure that you've completed step 1 first. The string has to be loose before doing this step.
  3. Baby Taylor Guitar String Replacement: passo 3, immagine 1 di 3 Baby Taylor Guitar String Replacement: passo 3, immagine 2 di 3 Baby Taylor Guitar String Replacement: passo 3, immagine 3 di 3
    • Take out the string from the bridge and the tuning pin.
    • You can now throw away the string. You will not be needing it anymore.
  4. Baby Taylor Guitar String Replacement: passo 4, immagine 1 di 2 Baby Taylor Guitar String Replacement: passo 4, immagine 2 di 2
    • Grab the new string and place the end (ball-end) inside the bridge.
    • The ball-end of a string is the side of the string that has a ball shape. (Shown in picture 2)
  5. Baby Taylor Guitar String Replacement: passo 5, immagine 1 di 2 Baby Taylor Guitar String Replacement: passo 5, immagine 2 di 2
    • Place the bridge pin inside the bridge in order to lock in the new string.
    • Lightly hammer down the bridge pin to keep it from detaching.
  6. Baby Taylor Guitar String Replacement: passo 6, immagine 1 di 2 Baby Taylor Guitar String Replacement: passo 6, immagine 2 di 2
    • Cut the excess string with a plier.
    • Cut the string around 1.5 inches over the desired tuning pin. (Recommended by Taylor Guitars)
  7. Baby Taylor Guitar String Replacement: passo 7, immagine 1 di 1
    • Place the new string inside the tuning pinhole.
    • It is recommended to place a really small portion of the string inside the pinhole to keep it from ripping your guitar bag. (As shown in the picture)
  8. Baby Taylor Guitar String Replacement: passo 8, immagine 1 di 3 Baby Taylor Guitar String Replacement: passo 8, immagine 2 di 3 Baby Taylor Guitar String Replacement: passo 8, immagine 3 di 3
    • Rotate the tuners in a counter-clockwise direction to tighten the new string.
    • You can either tighten it by hand (First Picture) or you can use the guitar string winder (Second Picture).
  9. Baby Taylor Guitar String Replacement: passo 9, immagine 1 di 1
    • Make sure your string is in tune and strum away!
Conclusione
Most guitar strings de-tune after they’ve been recently replaced. Tune your strings every once in a while for a few days and the strings will stay in tune.
Mohamed Saleh
Membro da: 09/18/21
230 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 750
