Salta al contenuto principale
Automatic Tommy 20 Dart Accelerator Replacement
Reed Garmsen
Reed Garmsen e 2 altri collaboratori
Ultimo aggiornamento il December 26, 2014
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
This guide will help teach you how to remove and replace the motorized accelerator near the the tip of the gun by first disassembling the gun, and then showing removal of the accelerator itself. The guide will require a #00 Phillips head screwdriver and requires you to keep track of a few small parts, but is very doable as long as you follow each step!
Cosa ti serve
Strumenti
  1. Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: passo 1, immagine 1 di 2 Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: passo 1, immagine 2 di 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Dart Accelerator Replacement: passo 2, immagine 1 di 3 Automatic Tommy 20 Dart Accelerator Replacement: passo 2, immagine 2 di 3 Automatic Tommy 20 Dart Accelerator Replacement: passo 2, immagine 3 di 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: passo 3, immagine 1 di 3 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: passo 3, immagine 2 di 3 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: passo 3, immagine 3 di 3
    • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
    • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
  4. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Bushing: passo 4, immagine 1 di 1
    • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
    • Remove the bushing by simply pulling it away from the plastic.
  5. Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: passo 5, immagine 1 di 2 Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: passo 5, immagine 2 di 2
    • Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
  6. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Accelerator: passo 6, immagine 1 di 1
    • Pull back on the accelerator away from the plastic to remove from frame.
    • Be careful to not pull too quickly or too hard to avoid damaging the wiring.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 6-22, Maness Fall 2014 Membro di Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,185
