Salta al contenuto principale
Asus X54C Keyboard Replacement
ZFix
ZFix e un altro collaboratore
Ultimo aggiornamento il February 21, 2017
3 - 5 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
ASUS X54C X54H X54HR - How to remove and replace the keyboard.
Cosa ti serve
Strumenti
Mostra di più…
Panoramica Video
  1. Asus X54C Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Asus X54C Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Disconnect the charger and switch off the laptop.
    • Two keys keep locked battery.
  2. Asus X54C Keyboard Replacement, Keyboard: passo 2, immagine 1 di 3 Asus X54C Keyboard Replacement, Keyboard: passo 2, immagine 2 di 3 Asus X54C Keyboard Replacement, Keyboard: passo 2, immagine 3 di 3
    • The Keyboard is held by 5x locking clips.
    • Use a tool with with a thin tip and lift slightly the KB from the left side.
    • Unlock clips one by one.
    • Disconnect the KB ribbon cable.
Conclusione
Altre 9 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
194.325 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.676 Guide realizzate
2Commenti sulla guida
Thanks for the detailed vid! What are the materials used at 07:00-08:00 to clean and replace the paste? Specifically what's in the spray bottle and the syringe
Buster Cluster - Replica
Hello,
To clean the thermal paste, the author used a soft toothbrush (probably with isopropyllic alcohol).
The syringe contains a non-conductive thermal paste.
You can replace the toothbrush by cell polyurethane foam swabs and isopropilic alcohol to remove the old thermal paste if you want.
This is a laptop with a CPU that doesn't heat too much, so you can replace the original thermal paste by any non conductive thermal paste made to be used in computers it will be fine.
Brendan -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 6,789
