Salta al contenuto principale
Asus Vivobook S500CA Touch Pad Replacement
Sydney Price
Sydney Price e 2 altri collaboratori
Ultimo aggiornamento il July 31, 2019
25 minuti
Moderato
Introduzione
Vai al passo 1
If your touch pad is unresponsive, follow this guide to replace the components.
Cosa ti serve
  1. Asus Vivobook S500CA Touch Pad Replacement, Touch Pad: passo 1, immagine 1 di 1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Touch Pad Replacement: passo 2, immagine 1 di 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 10mm screws and 7 5mm screws) around the perimeter of the back plate.
  3. Asus Vivobook S500CA Touch Pad Replacement: passo 3, immagine 1 di 1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Touch Pad Replacement: passo 4, immagine 1 di 1
    • Remove 9 5mm screws around the edge of the battery
  5. Asus Vivobook S500CA Touch Pad Replacement: passo 5, immagine 1 di 1
    • Lift up the battery to reveal the battery terminal.
  6. Asus Vivobook S500CA Touch Pad Replacement: passo 6, immagine 1 di 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clips.
  7. Asus Vivobook S500CA Touch Pad Replacement: passo 7, immagine 1 di 1
    • Remove the silver tape at the edge of the touch pad.
  8. Asus Vivobook S500CA Touch Pad Replacement: passo 8, immagine 1 di 1
    • Disconnect the white ribbon labeled “TP” by pulling gently.
  9. Asus Vivobook S500CA Touch Pad Replacement: passo 9, immagine 1 di 1
    • Remove 2 5mm screws from the hard drive casing.
  10. Asus Vivobook S500CA Touch Pad Replacement: passo 10, immagine 1 di 1
    • Slide the touch pad out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 660
