Salta al contenuto principale
Asus Vivobook S500CA RAM Replacement
Sydney Price
Sydney Price e 3 altri collaboratori
Ultimo aggiornamento il May 25, 2017
10 minuti
Facile
Introduzione
Vai al passo 1
If your computer is running slower than you would like, use this guide to replace your RAM. This model will support up to 8GB of RAM.
Cosa ti serve
  1. Asus Vivobook S500CA RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA RAM Replacement: passo 2, immagine 1 di 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. Asus Vivobook S500CA RAM Replacement: passo 3, immagine 1 di 1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA RAM Replacement: passo 4, immagine 1 di 1
    • Push away the tabs on the left and right sides of the RAM cartridge to release the cartridge.
    • Another pair of hands will make the process easier.
  5. Asus Vivobook S500CA RAM Replacement: passo 5, immagine 1 di 2 Asus Vivobook S500CA RAM Replacement: passo 5, immagine 2 di 2
    • Slide the cartridge directly away from its housing.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Un commento
You did not replace the RAM, nor give specifications on what RAM to replace it with (DDR3 1600 SDRAM DIMM etc)
Especially as it does not look like normal laptop memory (SODIMM)
facebook - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,316
