Salta al contenuto principale
Asus VivoBook X202E-DB21T CMOS Battery Replacement
John Thomas
John Thomas e 4 altri collaboratori
Ultimo aggiornamento il July 6, 2021
1 minuto
Moderato
Introduzione
Vai al passo 1
The CMOS battery is a small battery that allows the computer to remember the time and date. The battery also allows the computer to recover some memory in the case of an unexpected shutdown. If this battery no longer holds a charge, it can cause the computer to not function correctly.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 3, immagine 2 di 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T CMOS Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, immagine 1 di 2 Asus VivoBook X202E-DB21T CMOS Battery Replacement, CMOS Battery: passo 6, immagine 2 di 2
    • Unplug and remove the CMOS battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 123
Tutti i Tempi: 7,411
