Asus V500CA-DB51T Speaker Replacement
Introduzione
Vai al passo 1In this guide, you will learn how to replace the speakers in the Asus V500CA-DB51T. This guide was made to help with replacing broken or defective speakers, and is a moderately challenging repair.
Cosa ti serve
Strumenti
Mostra di più…
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Remove the following screws securing the battery connector board to the logic board:
The red screws are size 2.3 cm T6 Torx
The orange screws are size 2.4 cm T6 Torx
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using the tweezers gently remove the ribbon cable.
Also using the tweezers pry off the metallic tape on both sides of the mouse pad.
Remove the mouse pad from the main assembly.
