Salta al contenuto principale
Asus V500CA-DB51T RAM Replacement
Galen P Garofalo
Galen P Garofalo e 3 altri collaboratori
Ultimo aggiornamento il January 30, 2024
5 - 10 minuti
Facile
Attrezzi Non Corretti
Foto Azione
Introduzione
Vai al passo 1
In this guide, you will learn how to replace the RAM found inside the Asus V500CA-DB51T. This guide was made to help with replacing broken or defective RAM, and is an easy repair for any skill level.
Cosa ti serve
Strumenti
Mostra di più…
  1. Asus V500CA-DB51T RAM Replacement, Battery: passo 1, immagine 1 di 2 Asus V500CA-DB51T RAM Replacement, Battery: passo 1, immagine 2 di 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T RAM Replacement: passo 2, immagine 1 di 2 Asus V500CA-DB51T RAM Replacement: passo 2, immagine 2 di 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T RAM Replacement: passo 3, immagine 1 di 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T RAM Replacement: passo 4, immagine 1 di 2 Asus V500CA-DB51T RAM Replacement: passo 4, immagine 2 di 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T RAM Replacement: passo 5, immagine 1 di 3 Asus V500CA-DB51T RAM Replacement: passo 5, immagine 2 di 3 Asus V500CA-DB51T RAM Replacement: passo 5, immagine 3 di 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T RAM Replacement, RAM: passo 6, immagine 1 di 2 Asus V500CA-DB51T RAM Replacement, RAM: passo 6, immagine 2 di 2
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM will pop up by a few millimeters.
    • Pull the RAM stick out of its socket.
Conclusione
2Commenti sulla guida
"Step 6: Using a pair of tweezers, gently pull the RAM out of its socket." Uhhhh, NO!!!! This is horrible advice. Most tweezers are made of metal, rigid and have hard angles. #1, never touch anything metal to ANYTHING inside of a computer. You could send an electrostatic surge from your body through the tweezers to the object you're going to touch. THIS IS A GINORMOUS NO-NO!. Unless the tweezers are made of plastic or wood, you should never consider this, EVER!
The correct way to do this is to ground yourself with a grounding strap. If you don't have one of those, touch a piece of metal that may be grounded. If you don't have that, touch a computer case with both hands to drain your static charge, since computers are grounded. Then, WITH YOUR >>>HANDS ONLY<<<, remove the stick of memory.
I've been building computers for 20+ years. NEVER HAVE I EVER heard someone say use tweezers to touch any internal components. That's just a recipe for nuking your computer. DONT DO IT!
Jeff Oculush - Replica
Hi @jeffoculush, thank you for pointing that out! We've made an update to the guide to reflect proper instructions and also deleted the photo. Thanks again!
Sarah Westberg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 505
