Salta al contenuto principale
Asus Transformer T100 Button Module Replacement
Taylor Pantiga
Taylor Pantiga e 5 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
15 - 20 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
All the buttons on the tablet are located in one corner. They are all controlled by a button module board, which can be removed if desired.
Cosa ti serve
Strumenti
Mostra di più…
  1. Asus Transformer T100 Button Module Replacement, Rear Cover: passo 1, immagine 1 di 2 Asus Transformer T100 Button Module Replacement, Rear Cover: passo 1, immagine 2 di 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Button Module Replacement: passo 2, immagine 1 di 2 Asus Transformer T100 Button Module Replacement: passo 2, immagine 2 di 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - Replica
  3. Asus Transformer T100 Button Module Replacement: passo 3, immagine 1 di 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Button Module Replacement: passo 4, immagine 1 di 2 Asus Transformer T100 Button Module Replacement: passo 4, immagine 2 di 2
    • Remove the rear casing.
  5. Asus Transformer T100 Button Module Replacement, Button Module: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Unclip the white connection clip using a pair of tweezers.
  6. Asus Transformer T100 Button Module Replacement: passo 6, immagine 1 di 2 Asus Transformer T100 Button Module Replacement: passo 6, immagine 2 di 2
    • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
  7. Asus Transformer T100 Button Module Replacement: passo 7, immagine 1 di 1
    • Gently fold the connection apparatus back away from your work area.
  8. Asus Transformer T100 Button Module Replacement: passo 8, immagine 1 di 3 Asus Transformer T100 Button Module Replacement: passo 8, immagine 2 di 3 Asus Transformer T100 Button Module Replacement: passo 8, immagine 3 di 3
    • Remove the screws using a Phillips Head #1 screwdriver.
    • Remove the power button module.
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Taylor Pantiga
Membro da: 04/14/14
1.617 Reputazione
6 Guide realizzate
Cal Poly, Team 13-31, Maness Spring 2014 Membro di Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Membri
6 Guide realizzate
1Commento della guida
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 6,149
