Salta al contenuto principale
Asus ROG G751JL-DS71 Keyboard Replacement
Aurora Rios
Aurora Rios e 2 altri collaboratori
Ultimo aggiornamento il May 7, 2024
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show the user how to safely remove and replace the keyboard.
Cosa ti serve
Strumenti
Mostra di più…
  1. Asus ROG G751JL-DS71 Keyboard Replacement, CD-ROM Player: passo 1, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement, CD-ROM Player: passo 1, immagine 2 di 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
    The screw doesn't come out completely.
    Steve Menard - Replica
  2. Asus ROG G751JL-DS71 Keyboard Replacement: passo 2, immagine 1 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 2, immagine 2 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to remove the back center panel.
    Pull up on the rubber cover to aid the spudger.
  3. Asus ROG G751JL-DS71 Keyboard Replacement: passo 3, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    Why is it necessary to remove the CD Drive?
    Judi Pillsbury - Replica
  4. Asus ROG G751JL-DS71 Keyboard Replacement: passo 4, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement: passo 4, immagine 2 di 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Keyboard Replacement, Top Rear Panel: passo 5, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement, Top Rear Panel: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Asus ROG G751JL-DS71 Keyboard Replacement: passo 6, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement: passo 6, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  7. Asus ROG G751JL-DS71 Keyboard Replacement: passo 7, immagine 1 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 7, immagine 2 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 7, immagine 3 di 3
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  8. Asus ROG G751JL-DS71 Keyboard Replacement, Keyboard: passo 8, immagine 1 di 3 Asus ROG G751JL-DS71 Keyboard Replacement, Keyboard: passo 8, immagine 2 di 3 Asus ROG G751JL-DS71 Keyboard Replacement, Keyboard: passo 8, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
    There are 3 screws to remove on the left side as the rear of the laptop is facing you.
  9. Asus ROG G751JL-DS71 Keyboard Replacement: passo 9, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement: passo 9, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  10. Asus ROG G751JL-DS71 Keyboard Replacement: passo 10, immagine 1 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 10, immagine 2 di 3 Asus ROG G751JL-DS71 Keyboard Replacement: passo 10, immagine 3 di 3
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  11. Asus ROG G751JL-DS71 Keyboard Replacement: passo 11, immagine 1 di 2 Asus ROG G751JL-DS71 Keyboard Replacement: passo 11, immagine 2 di 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
    ON STEP 11
    Do not just pull the ribbons out! locate the grey bar on the connectors and lift them gently from the ribbon side upward, they will open and the ribbons will come away easily, replace the ribbons by putting them in place and clicking down the grey bars to lock them in.
    Off Duty Pastor - Replica
    Crud!! I didn't see your comment in time, Pastor! I am not accustomed to ribbon connectors. I found out too late, after severing one, that they each have “clips” locking them in place. This battery replacement just became complicated.
    This is the keyboard panel removal. What about removing the keyboard from the keyboard panel?
    tech cowboy - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Aurora Rios
Membro da: 01/22/18
917 Reputazione
4 Guide realizzate
Cal Poly, Team S16-G1, Banghart Winter 2018 Membro di Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Membri
22 Guide realizzate
1Commento della guida
Only shows you how to remove keyboard panel from chasis, not how to actually remove the keyborad from the keyboard panel to replace. sad.
Michael Chiu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 50
Tutti i Tempi: 3,703
