Salta al contenuto principale
Asus Chromebook Flip C100 Lower Case Replacement
Jesse Ye
Jesse Ye e 6 altri collaboratori
Ultimo aggiornamento il May 7, 2024
Nessuna stima
Moderato
Introduzione
Vai al passo 1
This prerequisite is required in order to replace or fix some components inside the bottom of the computer.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: passo 1, immagine 1 di 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: passo 3, immagine 1 di 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the two cables from the motherboard with tweezers
Conclusione
Altre 11 persone hanno completato questa guida.
Un commento
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 5,197
