Salta al contenuto principale
Asus Chromebook C523N Motherboard Replacement
Savannah Kramer
Savannah Kramer e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
15 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
The motherboard is extremely important to the overall function of your Asus Chromebook C523N. It is a printed circuit board that allows for the overall communication between many of the components, including the CPU, RAM, and many other hardwares.
Usually, the only other solution to an unresponsive motherboard is to buy an entirely new laptop. Without the hub of your laptop, most functions are nearly impossible.
Cosa ti serve
Strumenti
Mostra di più…
  1. Asus Chromebook C523N Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Motherboard Replacement: passo 2, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 2, immagine 2 di 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Motherboard Replacement: passo 3, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Motherboard Replacement, Battery: passo 4, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement, Battery: passo 4, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement, Battery: passo 4, immagine 3 di 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Motherboard Replacement: passo 5, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  8. Asus Chromebook C523N Motherboard Replacement: passo 8, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement: passo 8, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement: passo 8, immagine 3 di 3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  9. Asus Chromebook C523N Motherboard Replacement: passo 9, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement: passo 9, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement: passo 9, immagine 3 di 3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  10. Asus Chromebook C523N Motherboard Replacement: passo 10, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 10, immagine 2 di 2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  11. Asus Chromebook C523N Motherboard Replacement: passo 11, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement: passo 11, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  12. Asus Chromebook C523N Motherboard Replacement: passo 12, immagine 1 di 3 Asus Chromebook C523N Motherboard Replacement: passo 12, immagine 2 di 3 Asus Chromebook C523N Motherboard Replacement: passo 12, immagine 3 di 3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  13. Asus Chromebook C523N Motherboard Replacement: passo 13, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 13, immagine 2 di 2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  14. Asus Chromebook C523N Motherboard Replacement: passo 14, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 14, immagine 2 di 2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  15. Asus Chromebook C523N Motherboard Replacement: passo 15, immagine 1 di 2 Asus Chromebook C523N Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
Hi!
I assembled the motherboard but it isn't working. There is no power light. How to validate that the motherboard is functioning?
If I just connect power stream to its USBC power port the LED should be lighting?
mmm - Replica
I was following this guide and I found there were actually four screws holding the MB down. The red/blue/white/black speaker cable must also be disconnected to get the board out entirely.
Jaret Meier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 59
Tutti i Tempi: 4,028
