Salta al contenuto principale
Astro A50 Headband Replacement
Nicholas Eriksen
Nicholas Eriksen e 7 altri collaboratori
Ultimo aggiornamento il June 23, 2022
15 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
Please do not step on or misuse any of the pieces. Check to see if your head piece is broken or your adjusters are not working correctly.
Cosa ti serve
Ricambi
Strumenti
  1. Astro A50 Headband Replacement, Headband: passo 1, immagine 1 di 2 Astro A50 Headband Replacement, Headband: passo 1, immagine 2 di 2
    • Remove the six screws—three from each side of the headband
    • These screws have been glued. Apply heat in order to loosen the adhesive.
  2. Astro A50 Headband Replacement: passo 2, immagine 1 di 1
    • Remove the head piece from the ear pieces.
    • Separate the wire that connects the two ear pieces.
    • Replace or repair the broken head pieces.
    • A repair could be as simple as gluing the broken parts. When reinstalling to line up the adjusters correctly, make sure they function with the new parts before completely reassembling the head set.
Conclusione
Altre 3 persone hanno completato questa guida.
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Membro di UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 79
Tutti i Tempi: 18,279
