Introduzione
If your Arlo Pro 2 camera is not charging, follow this guide to walk you through the steps of replacing the Micro-USB charging port in your Arlo camera.
The Arlo Pro 2 battery usually last between 3 to 6 months on average. When battery has depleted the camera will no longer send motion captures to the connected device.
Make sure to inspect the USB port for any dirt or debris that may interfere with the connection.
Before starting this guide ensure that the camera is disconnected from any external power source.
Cosa ti serve
Press the release button on the camera and gently pull apart the casing to open the device.
Remove the battery from inside the case.
Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
Seperate the daughterboards from the motherboard and camera casing.
Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
Carefully pull the motherboard apart from the camera casing.
Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
Gently remove the Micro-USB port by pulling it away from the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1Commento della guida
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
