Salta al contenuto principale
Aorus X7 v2 I/O Board Replacement
Alexis Hernandez Jimenez
Alexis Hernandez Jimenez e 6 altri collaboratori
Ultimo aggiornamento il June 8, 2023
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
Follow these steps to replace the Aorus X7 v2 I/O Board for better sound quality and performance. Replacing the board can improve hardware support, graphics performance, and increase computer speed. It's recommended to replace the board every 2-4 years, but it can last up to 8 years. All you need is a new board, standard tools, and this guide to get started.
Cosa ti serve
Strumenti
  1. Aorus X7 v2 I/O Board Replacement, I/O Board: passo 1, immagine 1 di 3 Aorus X7 v2 I/O Board Replacement, I/O Board: passo 1, immagine 2 di 3 Aorus X7 v2 I/O Board Replacement, I/O Board: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $5.49
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Locate the speaker on the right-hand side of the device.
    • Remove the four red and black braided cables by gripping the black plastic piece on each cable and gently tugging to separate it from the white outlet.
  2. Aorus X7 v2 I/O Board Replacement: passo 2, immagine 1 di 3 Aorus X7 v2 I/O Board Replacement: passo 2, immagine 2 di 3 Aorus X7 v2 I/O Board Replacement: passo 2, immagine 3 di 3
    Phillips #0 Screwdriver
    $5.49
    • Use the Phillips #0 Screwdriver to remove the two screws holding the speaker in place. Lift off the speaker panel.
    • Use the Phillips #0 Screwdriver to remove the three screws holding the board in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
  3. Aorus X7 v2 I/O Board Replacement: passo 3, immagine 1 di 3 Aorus X7 v2 I/O Board Replacement: passo 3, immagine 2 di 3 Aorus X7 v2 I/O Board Replacement: passo 3, immagine 3 di 3
    $5.49
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the screw.
    • Place a finger under the board (see photo for location reference) and slowly lift up to remove the board.
Conclusione
Complete these steps in reverse order to install your new I/O Board.
Gateway, Team 1-4, Pee Fall 2022 Membro di Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 514
