Salta al contenuto principale
Anki Vector Infrared Sensor Replacement
Shay Takei
Shay Takei e 4 altri collaboratori
Ultimo aggiornamento il October 13, 2023
2 - 3 minuti
Moderato
Introduzione
Vai al passo 1
This guide will illustrate the process to remove or replace the infrared sensor of the Anki Vector. The only bit of equipment you will need to complete this guide is a screwdriver.
This guide should be helpful if your Anki Vector is having trouble distance tracking or mapping its environment.
Cosa ti serve
Strumenti
  1. Anki Vector Infrared Sensor Replacement, Belts: passo 1, immagine 1 di 1
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: passo 2, immagine 1 di 2 Anki Vector Infrared Sensor Replacement: passo 2, immagine 2 di 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: passo 3, immagine 1 di 2 Anki Vector Infrared Sensor Replacement, Infrared Sensor: passo 3, immagine 2 di 2
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: passo 4, immagine 1 di 2 Anki Vector Infrared Sensor Replacement: passo 4, immagine 2 di 2
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: passo 5, immagine 1 di 1
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: passo 6, immagine 1 di 2 Anki Vector Infrared Sensor Replacement: passo 6, immagine 2 di 2
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
Conclusione
Shay Takei
Membro da: 04/16/19
1.663 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G6, Maness Spring 2019 Membro di Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 787
