Salta al contenuto principale
Anker Soundcore Motion Boom Plus Tweeter Replacement
Cosa ti serve
    1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, immagine 1 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, immagine 2 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, immagine 3 di 3
      • Insert an opening tool into the seam between the speaker grille and the chassis.
      • Pry the tool around the top, bottom, and sides until the grille fully releases.
      • Apply gentle pressure to avoid damaging the grille.
      • Remove the grille.
      Chiedi a FixBot
      Aggiungi Commento
    2. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 2, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 2, immagine 2 di 2
      • Remove the two passive radiators on either side of the device.
      • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
      Chiedi a FixBot
      Aggiungi Commento
    3. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 3, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 3, immagine 2 di 2
      • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    4. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, immagine 1 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, immagine 2 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, immagine 3 di 3
      • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
      Chiedi a FixBot
      Aggiungi Commento
    5. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 5, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 5, immagine 2 di 2
      • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    6. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 6, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 6, immagine 2 di 2
      • Remove the eleven 13 mm Philips screws that secure the driver housing.
      Chiedi a FixBot
      Aggiungi Commento
    7. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 7, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 7, immagine 2 di 2
      • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
      Chiedi a FixBot
      Aggiungi Commento
    8. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 8, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 8, immagine 2 di 2
      • Remove the four 14 mm Philips screws on the top of the device.
      Chiedi a FixBot
      Aggiungi Commento
    9. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 9, immagine 1 di 1
      • Insert a spudger into the seam on top of the device.
      • Gently pry the casing open.
      Chiedi a FixBot
      Aggiungi Commento
    10. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, immagine 1 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, immagine 2 di 3 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, immagine 3 di 3
      • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
      • Do not pull with force. The ribbon cables are fragile and easily break.
      Chiedi a FixBot
      Aggiungi Commento
    1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: passo 11, immagine 1 di 2 Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: passo 11, immagine 2 di 2
      • Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
      • Avoid pulling too hard on the ribbon cables as they are fragile and easily break.
      Chiedi a FixBot
      Aggiungi Commento
    2. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 12, immagine 1 di 1
      • Push the tweeters from the front side, and the tweeters should pop out. Remove and replace the tweeters with new ones.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
Membro da: 03/26/25
988 Reputazione
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 10
Ultimi 30 giorni: 33
Tutti i Tempi: 325
