Salta al contenuto principale
Anker SoundCore 2 Bluetooth Chip Replacement
Cosa ti serve
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: passo 1, immagine 1 di 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: passo 1, immagine 2 di 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Chiedi a FixBot
      Aggiungi Commento
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, immagine 1 di 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, immagine 2 di 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, immagine 3 di 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      Chiedi a FixBot
      Aggiungi Commento
    2. Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, immagine 1 di 3 Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, immagine 2 di 3 Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, immagine 3 di 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: passo 4, immagine 1 di 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: passo 4, immagine 2 di 2
      • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
      • For help desoldering and soldering, follow this guide.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
1Commento della guida
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 69
Tutti i Tempi: 2,992
