Salta al contenuto principale
Android tablet Nobis NB09 Screen Replacement
Enea Osmann
Enea Osmann e 6 altri collaboratori
Ultimo aggiornamento il 3 gen 2024
5 - 10 minuti
Facile
Foto Azione
Attrezzi Non Corretti
Introduzione
Vai al passo 1
This is a guide on how to perform a screen replacement on a Nobis NB09 tablet. The screen is the most important part of the device when it comes to interacting with the tablet and users operating it in the first place. If the screen doesn’t work properly, then it becomes almost impossible to use the device at all.
It is advised to be cautious of possible shattered glass, and to use ESD-safe tools, as well as knowing how to properly use an anti-static mat and wristband.
Cosa ti serve
Strumenti
Mostra di più…
  1. Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 2, immagine 3 di 3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 3, immagine 3 di 3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 1 di 3 Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 2 di 3 Android tablet Nobis NB09 Screen Replacement: passo 4, immagine 3 di 3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Enea Osmann
Membro da: 10/31/14
158 Reputazione
1 Guida realizzata
2Commenti sulla guida
The digitizer replacement instructions was great. Thanks
steven warren - Replica
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,521
