Salta al contenuto principale
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
David Taylor
David Taylor e 7 altri collaboratori
Ultimo aggiornamento il July 11, 2024
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This repair guide will show you how to replace the top blade on your Andis T Outliner Trimmer with T Blade Model G.
A dull blade is the best indicator that you need to replace the blade. If your razor pulls your hairs or begins to feel rough on your skin, it’s likely time for a replacement.
The five-step process is easy. Each of the steps is accompanied by a brief description and photos demonstrating what you will need to do.
Note: The blade is sharp so use caution when handling it.
Cosa ti serve
Strumenti
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, immagine 1 di 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, immagine 2 di 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, immagine 3 di 3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, immagine 1 di 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, immagine 2 di 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, immagine 3 di 3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: passo 3, immagine 1 di 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: passo 3, immagine 2 di 2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: passo 4, immagine 1 di 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: passo 4, immagine 2 di 2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: passo 5, immagine 1 di 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: passo 5, immagine 2 di 2
    • Clean or lubricate the device if necessary.
Conclusione
Altre 3 persone hanno completato questa guida.
David Taylor
Membro da: 10/08/14
169 Reputazione
1 Guida realizzata
USF Tampa, Team 1-34, Donnelly Fall 2014 Membro di USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Membro
2 Guide realizzate
Un commento
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 7,118
