Salta al contenuto principale
Ambient Weather WS-1001-Wifi Battery Replacement
Taylor Whitaker
Taylor Whitaker e 5 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
In this fix we will be looking at how to replace the internal battery used to store electrical charge for the device. This will require a Phillips #1 screwdriver, a small plastic tool to remove the LCD screen and to remove the battery.
Good Luck!
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: passo 1, immagine 1 di 2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: passo 1, immagine 2 di 2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: passo 2, immagine 1 di 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: passo 3, immagine 1 di 2 Ambient Weather WS-1001-Wifi Battery Replacement: passo 3, immagine 2 di 2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Conclusione
IUPUI, Team S1-G2, Harley Fall 2017 Membro di IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Membri
3 Guide realizzate
Un commento
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 836
