Salta al contenuto principale
Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement
Cassidy O'Connor
Cassidy O'Connor e 2 altri collaboratori
Ultimo aggiornamento il 10 gen 2018
15 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the analog to digital convertor on the Amazon Echo Dot. This component is located on the LED/speaker board, however, the whole board must be replaced, rather than just the analog to digital convertor.
Cosa ti serve
Strumenti
Mostra di più…
  1. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: passo 1, immagine 1 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: passo 1, immagine 2 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement, Analog to Digital Convertor: passo 1, immagine 3 di 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 2, immagine 1 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 2, immagine 2 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 2, immagine 3 di 3
    • Use a T8 screwdriver to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 3, immagine 1 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 3, immagine 2 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 3, immagine 3 di 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 5, immagine 1 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 5, immagine 2 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 5, immagine 3 di 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 6, immagine 1 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 6, immagine 2 di 3 Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 6, immagine 3 di 3
    • Remove the ribbon cable from the slot on the speaker board
  7. Amazon Echo Dot 2nd Generation Analog to Digital Convertor Replacement: passo 7, immagine 1 di 1
    • Remove the speaker board which contains the analog to digital converter
Conclusione
Preparati per le riparazioni future
Acquista tutti
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro di USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,615
