Salta al contenuto principale
Alpine Ski Wax Application
Evan Gornick
Evan Gornick e 3 altri collaboratori
Ultimo aggiornamento il July 20, 2023
1 ora
Moderato
Introduzione
Vai al passo 1
This guide will show you how to apply hot wax to alpine skis. Overtime routine ware causes the bottom of the skis to become scratched and chipped. Applying wax will restore the bottoms to near perfect condition if completed correctly.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Alpine Ski Wax Application, Alpine Ski Wax Application: passo 1, immagine 1 di 1
    • Attach heavy rubber bands around the brakes.
  2. Alpine Ski Wax Application: passo 2, immagine 1 di 1
    • Spray base cleaner along the bottom of the ski.
  3. Alpine Ski Wax Application: passo 3, immagine 1 di 1
    • Wipe the skis with a towel, removing dirt, excess wax, the base cleaner, and dust.
  4. Alpine Ski Wax Application: passo 4, immagine 1 di 1
    • Spread wax across the base of the ski with an edge to edge motion. While doing this hold the iron perpendicular to the base and press the wax into the iron.
    • Be careful when handling the hot iron and the hot wax.
  5. Alpine Ski Wax Application: passo 5, immagine 1 di 1
    • Melt the wax into the base using a tip to tail stroke with the iron.
    • Let the skis dry for at least 30 minutes once all the wax is melted.
  6. Alpine Ski Wax Application: passo 6, immagine 1 di 1
    • Scrape the excess wax off with the plastic scraper. Continue this process until there is no visible wax on the ski base.
  7. Alpine Ski Wax Application: passo 7, immagine 1 di 1
    • Scrape the excess wax off of the side of the ski.
  8. Alpine Ski Wax Application: passo 8, immagine 1 di 1
    • Wipe the fine wax dust from the ski base.
Linea Traguardo
Evan Gornick
Membro da: 09/26/17
101 Reputazione
1 Guida realizzata
8 Commenti
Very nice post! That's a great website I have visited, thank you for your essentials words run 3
Martin Tolley - Replica
I read your article very detailed and easy to understand, I hope next time you will have more wonderful articles to share with the reader.
run 3
switch color - Replica
thansks for the post
Arun nagar - Replica
'''WYSIWYG Web Builder Crack''' has a unique and easy to use tools for both beginners and professional developers. Hence it is straightforward to use application.
Harry Oscar - Replica
I really enjoy the blog article. Much thanks again. Want more.
Wondershare Filmora Scrn Crack
DxO PhotoLab Crack
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 432
