Salta al contenuto principale
Alienware X51 R2/R3 CPU Replacement
rcschwartz709
rcschwartz709 e 2 altri collaboratori
Ultimo aggiornamento il August 1, 2024
10 - 20 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Before you start this project, you should take proper precautions. Before you start anything, you need to unplug the computer from the wall. Unplugging the computer is a must to avoid electrocution. It is recommended to take precautions against ESD by using an anti-static mat and a grounding cable. The only tool you will need for this fix is a screwdriver. You will also need a replacement CPU and thermal grease.
Cosa ti serve
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): passo 1, immagine 1 di 1
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
  2. Alienware X51 R2/R3 CPU Replacement: passo 2, immagine 1 di 1
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
  3. Alienware X51 R2/R3 CPU Replacement: passo 3, immagine 1 di 1
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
  4. Alienware X51 R2/R3 CPU Replacement: passo 4, immagine 1 di 1
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
  5. Alienware X51 R2/R3 CPU Replacement: passo 5, immagine 1 di 1
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
Conclusione
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
Altre 2 persone hanno completato questa guida.
rcschwartz709
Membro da: 07/02/16
220 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,704
