Salta al contenuto principale
Alienware M11x Memory Module Replacement
darrius
darrius e 3 altri collaboratori
Ultimo aggiornamento il November 1, 2019
5 - 10 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
In this guide, we will be showing you how to remove and replace the Memory Module.
Cosa ti serve
Strumenti
  1. Alienware M11x Memory Module Replacement, Introduction: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, immagine 1 di 2 Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, immagine 2 di 2
    • Remove the memory module from the memory module connector.
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: passo 4, immagine 1 di 1
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: passo 5, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 351
