Salta al contenuto principale
Acoustic Bass Preamp Replacement
Juan Chavez
Juan Chavez e 3 altri collaboratori
Ultimo aggiornamento il June 28, 2024
1 - 2 ore
Moderato
Necessarie Immagini Migliori
Necessarie Più Immagini
Introduzione
Vai al passo 1
This guide will help you replace the preamp for your acoustic bass. This guide can also be applied to other guitars because of the similar process.
For this process, make sure to purchase a preamp kit that will fit your bass or guitar.
  1. Acoustic Bass Preamp Replacement, Preamp: passo 1, immagine 1 di 2 Acoustic Bass Preamp Replacement, Preamp: passo 1, immagine 2 di 2
    • Use a guitar string winder to carefully remove each string.
  2. Acoustic Bass Preamp Replacement: passo 2, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 2, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 2, immagine 3 di 3
    • Look inside the bass for the preamp tuning box.
    • Once you find it, unplug the small jack.
  3. Acoustic Bass Preamp Replacement: passo 3, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 3, immagine 2 di 2
    • Cut the zip tie holding the excess length of wires in place. This is located inside the bass.
    • The zip tie is most likely right under the bridge of the bass.
    • This will allow you to disassemble all parts the wires will connect to later on in the repair.
  4. Acoustic Bass Preamp Replacement: passo 4, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 4, immagine 2 di 2
    • Pull out the pick-up stick from the bridge of the base.
  5. Acoustic Bass Preamp Replacement: passo 5, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 5, immagine 2 di 2
    • Look for the tuner/equalizer/preamp and carefully remove each screw using a Phillips screwdriver.
    • Once screws are removed, look for the endpin jack and remove it.
    • In the first image, the part had already fallen off. Refer to the second image if you have trouble finding the endpin jack.
  6. Acoustic Bass Preamp Replacement: passo 6, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 6, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 6, immagine 3 di 3
    • Place the tuner over the area you removed the previous one from.
    • Scratch a line around the opening to the area of the bottom portion of the tuner.
    • Refer to the second image for a visual reference.
    • Ensure the scratched guideline is made to the parameter of the parts behind the face of the tuner.
  7. Acoustic Bass Preamp Replacement: passo 7, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 7, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 7, immagine 3 di 3
    • Using a metal file, file up and down, following the outline.
    • Continue this, going around the outline until the desired opening is made.
    • This will most likely take quite a bit of time. If you have access to a small jab saw or similar power tool it will speed up the process.
    • Do this step ideally in a well-ventilated area as the wood shaving are small, and inhalation can cause harm or injury. Wear protective gear like a face mask, and goggles/eye protection to prevent injury or pain.
  8. Acoustic Bass Preamp Replacement: passo 8, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 8, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 8, immagine 3 di 3
    • Get your output platform and measure, with a ruler, the perimeter of the parts under the face with the screw holes.
    • The second and third images show the underside of the part, measuring around the internals.
    • Once you measure each side, jot them down for Step 9.
  9. Acoustic Bass Preamp Replacement: passo 9, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 9, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 9, immagine 3 di 3
    • Use a pencil and paper to outline the measurements jotted down.
    • Cut the shape out using a pair of scissors.
    • Place the paper over the opening on the guitar and trace the perimeter of the paper.
  10. Acoustic Bass Preamp Replacement: passo 10, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 10, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 10, immagine 3 di 3
    • Insert the file into the opening and file up until you reach the outline you traced.
    • Then follow the outline until the opening is completely cut out.
    • Do this step ideally in a well-ventilated area as the wood shaving are small, and you may inhale them.
  11. Acoustic Bass Preamp Replacement: passo 11, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 11, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 11, immagine 3 di 3
    • Place the preamp into the opening and screw into place with your power drill.
    • A power drill and four screws are required in this step. This will allow you to create a hole to screw in the screws or just directly screw in the screw without drilling holes.
  12. Acoustic Bass Preamp Replacement: passo 12, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 12, immagine 2 di 2
    • Using your power drill and the other four screws, drill the screws into the output platform openings.
  13. Acoustic Bass Preamp Replacement: passo 13, immagine 1 di 3 Acoustic Bass Preamp Replacement: passo 13, immagine 2 di 3 Acoustic Bass Preamp Replacement: passo 13, immagine 3 di 3
    • Get your pickup stick and insert it into the hole in the bridge.
    • Look into the guitar for the end of the pick-up stick and pull it until it reaches the preamp box.
    • Plug in the pickup stick jack into the box, as seen in the fourth image.
  14. Acoustic Bass Preamp Replacement: passo 14, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 14, immagine 2 di 2
    • Look for the preamp inside the bass. You will find a wire showed in the first image.
    • Stretch your arm into the bass to reach the output platform and find where you will need to plug the wire into.
    • Ensure the wire plugs in the right way and is firmly plugged in.
  15. Acoustic Bass Preamp Replacement: passo 15, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 15, immagine 2 di 2
    • Use a zip tie to secure the extra length of wire inside the bass.
    • This step is not required but will help disguise wires and keep them tucked inside the bass.
  16. Acoustic Bass Preamp Replacement: passo 16, immagine 1 di 2 Acoustic Bass Preamp Replacement: passo 16, immagine 2 di 2
    • Replace the old strings or install new strings to the bass.
    • Use the string winder to make this step a lot faster.
Conclusione
Congratulations! You have just retrofitted a new amp into your bass.
Had trouble with one of the steps? Leave a comment letting us know how we can help!
Juan Chavez
Membro da: 04/03/23
304 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 820
