Salta al contenuto principale
Acer Spin 5 N17W2 Trackpad Replacement
William
William e un altro collaboratore
Ultimo aggiornamento il July 1, 2020
6 - 10 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
The trackpad is the component that tracks all user finger movement on a laptop. If your laptop is not properly tracking the movements of your cursor, the trackpad may need to be replaced. Follow these instructions to remove and replace the trackpad in your device.
Cosa ti serve
Strumenti
  1. Acer Spin 5 N17W2 Trackpad Replacement, Battery: passo 1, immagine 1 di 2 Acer Spin 5 N17W2 Trackpad Replacement, Battery: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Trackpad Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Trackpad Replacement: passo 3, immagine 1 di 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Trackpad Replacement: passo 4, immagine 1 di 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Trackpad Replacement: passo 5, immagine 1 di 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Trackpad Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Trackpad Replacement, Trackpad: passo 7, immagine 1 di 1
    • Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
  8. Acer Spin 5 N17W2 Trackpad Replacement: passo 8, immagine 1 di 1
    • Remove ribbon cables connected to the middle of the mouse pad.
    • Remove the adhesive tape from the left side of the mouse pad.
  9. Acer Spin 5 N17W2 Trackpad Replacement: passo 9, immagine 1 di 1
    • Using the phillips #1 screwdriver, remove the 4 screws securing the mouse pad.
  10. Acer Spin 5 N17W2 Trackpad Replacement: passo 10, immagine 1 di 1
    • Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 789
