Salta al contenuto principale
Acer Spin 5 N17W2 SSD Replacement
Noah Ryan Collier
Noah Ryan Collier e 3 altri collaboratori
Ultimo aggiornamento il November 27, 2023
10 minuti
Facile
Necessarie Immagini Migliori
Necessarie Più Immagini
Introduzione Migliore
Introduzione
Vai al passo 1
Use this guide to replace the SSD in your device.
Cosa ti serve
Strumenti
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mostra di più…
  1. Acer Spin 5 N17W2 SSD Replacement, Battery: passo 1, immagine 1 di 2 Acer Spin 5 N17W2 SSD Replacement, Battery: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 SSD Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 SSD Replacement: passo 3, immagine 1 di 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 SSD Replacement: passo 4, immagine 1 di 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 SSD Replacement: passo 5, immagine 1 di 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 SSD Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 SSD Replacement, SSD: passo 7, immagine 1 di 1
    • Disconnect the SSD from the laptop.
    • At the time of guide creation, the device did not come equipped with the SSD.
Conclusione
2Commenti sulla guida
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - Replica
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Stephen Feger -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,152
