Acer Spin 5 N17W2 Hard Drive Replacement
Introduzione
Vai al passo 1The hard drive is the storage component of a laptop or computer. If you’re unable to read files or access files in your computer, your hard drive may be corrupted and needs to be replaced. Use this guide to replace the hard drive in your device.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
2 Commenti
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
