Salta al contenuto principale
Acer Chromebook C710-2833 Speakers Replacement
Ethan DeRuby
Ethan DeRuby e 5 altri collaboratori
Ultimo aggiornamento il May 16, 2024
2 ore
Moderato
Introduzione
Vai al passo 1
With use or improper care, the speakers of your laptop may become faulty. The speakers might need to be replaced if they produce a gargled or popping noise or are not responsive at all. Place your ear near the speaker while playing any sound to determine if either speaker is functioning. Replace the speakers with this guide.
Cosa ti serve
Strumenti
Mostra di più…
  1. Acer Chromebook C710-2833 Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Speakers Replacement: passo 2, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Speakers Replacement: passo 3, immagine 1 di 1
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 Speakers Replacement: passo 4, immagine 1 di 1
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 Speakers Replacement: passo 5, immagine 1 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 5, immagine 2 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 5, immagine 3 di 3
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 Speakers Replacement: passo 6, immagine 1 di 1
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 Speakers Replacement: passo 7, immagine 1 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 7, immagine 2 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 7, immagine 3 di 3
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 Speakers Replacement: passo 8, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 Speakers Replacement: passo 9, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 9, immagine 2 di 2
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 Speakers Replacement: passo 10, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 10, immagine 2 di 2
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 Speakers Replacement: passo 11, immagine 1 di 1
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 Speakers Replacement: passo 12, immagine 1 di 1
    • Remove the four 3 mm Phillips #00 speaker screws.
    • Note that these screws have an especially large diameter head.
  13. Acer Chromebook C710-2833 Speakers Replacement: passo 13, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 13, immagine 2 di 2
    • Using the opening tool, gently pull out the connector that connects the left speaker to the motherboard.
    • Lift, but do not completely remove the speakers. They are still attached by wire.
  14. Acer Chromebook C710-2833 Speakers Replacement: passo 14, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 14, immagine 2 di 2
    • Using the opening tool, gently pull the two connector flanges holding the large ribbon cable.
    • Gently pull the large ribbon cable to disconnect it.
  15. Acer Chromebook C710-2833 Speakers Replacement: passo 15, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 15, immagine 2 di 2
    • Use an opening tool to remove the head of the last connected ribbon cable.
    • With your hand, grasp the pull tab and disconnect the ribbon cable.
  16. Acer Chromebook C710-2833 Speakers Replacement: passo 16, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 16, immagine 2 di 2
    • Using the opening tool, gently pull the connector flange connecting the small wires.
    • Gently pull the black connector from the cream-colored connector to disconnect the wires.
  17. Acer Chromebook C710-2833 Speakers Replacement: passo 17, immagine 1 di 1
    • Remove the 3mm #00 Phillips screw near the bottom of the blue board.
  18. Acer Chromebook C710-2833 Speakers Replacement: passo 18, immagine 1 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 18, immagine 2 di 3 Acer Chromebook C710-2833 Speakers Replacement: passo 18, immagine 3 di 3
    • Using the opening tool, gently pry the main circuit board out of the casing.
    • Gently tilt the main circuit board up.
    • Place the circuit board to the side.
    • The circuit board is still connected at the hinge top left, do not attempt to remove it.
  19. Acer Chromebook C710-2833 Speakers Replacement: passo 19, immagine 1 di 2 Acer Chromebook C710-2833 Speakers Replacement: passo 19, immagine 2 di 2
    • Remove the black tape over the wire, holding it in.
    • Remove the wire from under the hooks keeping it in place.
    • The speakers and wires are now ready to be removed, and new ones installed.
Conclusione
Ethan DeRuby
Membro da: 09/24/17
298 Reputazione
1 Guida realizzata
IUPUI, Team S1-G6, Harley Fall 2018 Membro di IUPUI, Team S1-G6, Harley Fall 2018
IUPUI-HARLEY-F18S1G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 648
