Acer Aspire One Cloudbook 11 AO1-131-C7DW Motherboard Replacement
Introduzione
Vai al passo 1The motherboard is a key component for any laptop and a damaged motherboard means that the laptop will not work as intended. This guide shows you how to replace the motherboard for this laptop.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Position the computer so the opening side faces you.
Remove the tape holding the WiFi module using tweezers.
Unplug the speaker connector using tweezers.
