Salta al contenuto principale
Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement
Luz Villegas
Luz Villegas e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
8 minuti
Facile
Introduzione
Vai al passo 1
If the life of your battery is significantly shortened, it may be damaged or old. This guide can help you replace the battery by yourself!
Cosa ti serve
Strumenti
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement, Back Panel: passo 1, immagine 1 di 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement, Back Panel: passo 1, immagine 2 di 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement, Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 2, immagine 2 di 2
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 3, immagine 1 di 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 3, immagine 2 di 3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 3, immagine 3 di 3
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 4, immagine 1 di 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 4, immagine 2 di 2
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 5, immagine 1 di 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 5, immagine 2 di 2
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
  6. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement, Battery: passo 6, immagine 1 di 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Flip the back panel so the battery faces down.
    • Remove the rubber foot with tweezers.
  7. Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 7, immagine 1 di 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Battery Replacement: passo 7, immagine 2 di 2
    • Remove the 5-mm screw that is located underneath the rubber foot using the PH0 screwdriver.
    • Lift the battery and detach it from the back panel.
Conclusione
Luz Villegas
Membro da: 09/08/17
452 Reputazione
4 Guide realizzate
Un commento
Anyone have a link for this exact laptop battery please?
Simon Morgans - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,527
