Salta al contenuto principale
Acer Aspire E5-721-64T8 battery  Replacement
Reem
Reem e 3 altri collaboratori
Ultimo aggiornamento il June 25, 2018
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
If the laptop is failing to turn on or hold a charge, it may be because of a faulty battery. This guide will teach you how to remove and therefor replace the battery of this laptop. Be sure to disconnect the AC adapter to your laptop if it's connected before removal.
Cosa ti serve
Strumenti
Mostra di più…
  1. Acer Aspire E5-721-64T8 battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 battery  Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 battery  Replacement: passo 3, immagine 1 di 1
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 battery  Replacement: passo 4, immagine 1 di 2 Acer Aspire E5-721-64T8 battery  Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
Conclusione
Reem
Membro da: 01/25/18
109 Reputazione
1 Guida realizzata
USF Tampa, Team S7-G3, Passmore Spring 2018 Membro di USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 648
