Salta al contenuto principale
Acer Aspire E5-573G Optical Drive Replacement
Alex Bahm
Alex Bahm e 3 altri collaboratori
Ultimo aggiornamento il June 29, 2020
30 secondi - 1 minuto
Molto facile
Introduzione
Vai al passo 1
The base model of the Acer Aspire E5-573G comes with an expansion slot for an optical drive, but no actual drive. This guide will show you how to remove that expansion and replace it with a functioning optical drive.
Cosa ti serve
Strumenti
  1. Acer Aspire E5-573G Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Optical Drive Replacement: passo 2, immagine 1 di 1
    • Pull out the disk drive.
Conclusione
Altre 5 persone hanno completato questa guida.
Alex Bahm
Membro da: 01/18/18
2.311 Reputazione
6 Guide realizzate
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro di Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Membri
15 Guide realizzate
2 Commenti
What is the size of the disc drive? I've looked all over the internet and can't find it anywhere. Even Acer's own website does not give the size.
Gareth Headland - Replica
is it 9.5mm or 12.7mm?
mirddes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,462
