Salta al contenuto principale
Acer Aspire E5-573G Fan  Replacement
Lara Mustafa
Lara Mustafa e un altro collaboratore
Ultimo aggiornamento il June 3, 2021
30 minuti
Moderato
Introduzione
Vai al passo 1
After a while, your laptop fan could get clogged with dust and start overheating or it could get damaged due to excessive usage. Fans remove heat from the interior of the laptop. move heat away from hardware. The main objective of this is to prevent overheating, something electronics is severely sensitive with as well. This guide will help you replace your Acer Aspire E5-573G fan with easy to moderate steps that can be done at home to prevent internal damage to your hardware.
Cosa ti serve
Strumenti
Mostra di più…
  1. Acer Aspire E5-573G Fan  Replacement, Fan: passo 1, immagine 1 di 2 Acer Aspire E5-573G Fan  Replacement, Fan: passo 1, immagine 2 di 2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
  2. Acer Aspire E5-573G Fan  Replacement: passo 2, immagine 1 di 2 Acer Aspire E5-573G Fan  Replacement: passo 2, immagine 2 di 2
    • Remove the CD drive located on the side of the laptop.
  3. Acer Aspire E5-573G Fan  Replacement: passo 3, immagine 1 di 1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
  4. Acer Aspire E5-573G Fan  Replacement: passo 4, immagine 1 di 3 Acer Aspire E5-573G Fan  Replacement: passo 4, immagine 2 di 3 Acer Aspire E5-573G Fan  Replacement: passo 4, immagine 3 di 3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
  5. Acer Aspire E5-573G Fan  Replacement: passo 5, immagine 1 di 2 Acer Aspire E5-573G Fan  Replacement: passo 5, immagine 2 di 2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
  6. Acer Aspire E5-573G Fan  Replacement: passo 6, immagine 1 di 3 Acer Aspire E5-573G Fan  Replacement: passo 6, immagine 2 di 3 Acer Aspire E5-573G Fan  Replacement: passo 6, immagine 3 di 3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
Conclusione
Lara Mustafa
Membro da: 01/08/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,021
