Salta al contenuto principale
Acer Aspire 5750-6677 Hard Drive Replacement
Zachary Ferreira
Zachary Ferreira e 5 altri collaboratori
Ultimo aggiornamento il November 18, 2022
8 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
The goal of this guide is to help replace the hard drive of your Acer Aspire 5750-6677. People replace their hard drives in order to have a new one with better capacity and performance capabilities. Hard drives need to be replaced in three to four years in order to prevent them from failing. The hard drive’s purpose is to store any data, pictures, music, videos and any files created or downloaded. This replacement process is considered to be easy and will only take around eight minutes. There are no special skills required and the only tool you will need is a Phillips #0 screwdriver.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Acer Aspire 5750-6677 Hard Drive Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Acer Aspire 5750-6677 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Hard Drive Replacement: passo 5, immagine 1 di 2 Acer Aspire 5750-6677 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Pull the tab and lift up to remove the hard drive.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,577
