Salta al contenuto principale
Acer Aspire 5 A515-56-347N Bottom Cover Replacement
Henry Bryant
Henry Bryant e 3 altri collaboratori
Ultimo aggiornamento il June 27, 2024
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
If you need to access any internal components of your Acer Aspire 5 A515-56-347N, this guide will explain how to remove the bottom cover in order to service your laptop's internal components.
Electrostatic discharge (ESD) can irreparably damage the components of your computer. While following this guide, avoid wearing static-prone clothing such as wool or flannel, or working on surfaces such as carpet. Optionally, you may use an ESD bracelet and/or mat to remain grounded throughout the repair process and minimize the risk of ESD damage.
For additional information, you may consult this device's safety guide and user manual (see attachments), or the manufacturer's support page.
Cosa ti serve
Strumenti
Mostra di più…
  1. Acer Aspire 5 A515-56-347N Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 2 Acer Aspire 5 A515-56-347N Bottom Cover Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Acer Aspire 5 A515-56-347N Bottom Cover Replacement: passo 2, immagine 1 di 3 Acer Aspire 5 A515-56-347N Bottom Cover Replacement: passo 2, immagine 2 di 3 Acer Aspire 5 A515-56-347N Bottom Cover Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 336
