Salta al contenuto principale
Acer Aspire 4520-5464 Hard Drive Replacement
Hunter Gilcrease
Hunter Gilcrease e 3 altri collaboratori
Ultimo aggiornamento il January 5, 2018
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide demonstrates how to replace or upgrade the Hard Drive of an Acer Aspire 4520-5464 laptop.
Cosa ti serve
Strumenti
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: passo 2, immagine 1 di 2 Acer Aspire 4520-5464 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, immagine 1 di 3 Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, immagine 2 di 3 Acer Aspire 4520-5464 Hard Drive Replacement: passo 5, immagine 3 di 3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the hard drive from the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 921
