Salta al contenuto principale
Acer Aspire 3000 RAM Replacement
roro6730
roro6730 e un altro collaboratore
Ultimo aggiornamento il December 13, 2016
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
This RAM replacement guide will prove to be very useful for devices that contain a faulty RAM. Often times the RAM slows performance of the device or stops it entirely. In order to optimize the computers performance a careful RAM replacement must be executed. However, it is important to follow the steps with care because the RAM ports are fragile and vital to the device. If the ports do become damaged the device will not likely work.
Cosa ti serve
Strumenti
Mostra di più…
  1. Acer Aspire 3000 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 RAM Replacement: passo 2, immagine 1 di 2 Acer Aspire 3000 RAM Replacement: passo 2, immagine 2 di 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 RAM Replacement: passo 3, immagine 1 di 2 Acer Aspire 3000 RAM Replacement: passo 3, immagine 2 di 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
  5. Acer Aspire 3000 RAM Replacement: passo 5, immagine 1 di 1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
  6. Acer Aspire 3000 RAM Replacement: passo 6, immagine 1 di 1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
  7. Acer Aspire 3000 RAM Replacement: passo 7, immagine 1 di 1
    • Lift and pull the cover back towards you to detach it from the device.
  8. Acer Aspire 3000 RAM Replacement: passo 8, immagine 1 di 1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
  9. Acer Aspire 3000 RAM Replacement: passo 9, immagine 1 di 1
    • Pull and lift the chip to release it from the RAM port.
  10. Acer Aspire 3000 RAM Replacement: passo 10, immagine 1 di 1
    • Repeat step 9 to release the bottom chip from its RAM port.
Conclusione
Altre 2 persone hanno completato questa guida.
roro6730
Membro da: 10/30/16
351 Reputazione
2 Guide realizzate
Baylor, Team 4-2, Williams Fall 2016 Membro di Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 750
