Salta al contenuto principale
Abu Garcia Black Max Spool Replacement
Daniel Minev
Daniel Minev e un altro collaboratore
Ultimo aggiornamento il May 9, 2024
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
In this guide, we will be replacing the spool on the Abu Garcia Black Max bait casting reel.
The typical spool on a bait casting reel should last an extremely long time and does not need to be typically replaced. On the other hand, if you use your reel in salt water without proper maintenance, the spool could corrode.
This guide will begin with the removal of the spool, following a few simple steps, then taking the old spool and replacing it with the new spool. Finally, we will reassemble the reel back together.
If you have found your spool to be damaged, corroded, or just want to switch it out with a new spool, this guide is for you.
  1. Abu Garcia Black Max Spool Replacement, Spool: passo 1, immagine 1 di 2 Abu Garcia Black Max Spool Replacement, Spool: passo 1, immagine 2 di 2
    • Make sure you take off all the line on the reels spool.
  2. Abu Garcia Black Max Spool Replacement: passo 2, immagine 1 di 2 Abu Garcia Black Max Spool Replacement: passo 2, immagine 2 di 2
    • Take the black pin and apply pressure, pushing the pin to the left until it cannot go further.
    • On the right side of the reel, pull the side panel towards you until it pops up toward you.
  3. Abu Garcia Black Max Spool Replacement: passo 3, immagine 1 di 1
    • Make sure you are still holding the pin to the left.
    • Slowly pull the side panel to the right until it comes off completely.
  4. Abu Garcia Black Max Spool Replacement: passo 4, immagine 1 di 1
    • Grab the spool with your fingers, and gently pull out the spool from the reel.
    • Grab your replacement spool and have it ready for the next step.
  5. Abu Garcia Black Max Spool Replacement: passo 5, immagine 1 di 1
    • Take your replacement spool and put the spool back inside the reel, the same way you pulled out the old spool.
  6. Abu Garcia Black Max Spool Replacement: passo 6, immagine 1 di 1
    • Make sure that there are no spaces in the left and right sides of the spool once the new spool is in.
  7. Abu Garcia Black Max Spool Replacement: passo 7, immagine 1 di 2 Abu Garcia Black Max Spool Replacement: passo 7, immagine 2 di 2
    • Pull the pin to the left again.
    • Place the black side panel back onto the reel.
    • Once the black side panel is back on, apply downward pressure, pushing the black side panel back, until it clicks into place.
  8. Abu Garcia Black Max Spool Replacement: passo 8, immagine 1 di 1
    • You have now done a complete spool replacement on the Abu Garcia Black Max baitcasting reel.
    • When you decide, you can now put the line back onto the spool.
Linea Traguardo
Daniel Minev
Membro da: 01/10/24
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 36
Tutti i Tempi: 417
