Salta al contenuto principale
ASUS Q405U Battery Replacement
Cosa ti serve
    1. ASUS Q405U Battery Replacement, Back Cover: passo 1, immagine 1 di 1
      • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. ASUS Q405U Battery Replacement: passo 2, immagine 1 di 1
      • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. ASUS Q405U Battery Replacement: passo 3, immagine 1 di 3 ASUS Q405U Battery Replacement: passo 3, immagine 2 di 3 ASUS Q405U Battery Replacement: passo 3, immagine 3 di 3
      • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
      Chiedi a FixBot
      Aggiungi Commento
    4. ASUS Q405U Battery Replacement: passo 4, immagine 1 di 2 ASUS Q405U Battery Replacement: passo 4, immagine 2 di 2
      • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
      • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
      • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    1. ASUS Q405U Battery Replacement, Battery: passo 5, immagine 1 di 1
      • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. ASUS Q405U Battery Replacement: passo 6, immagine 1 di 1
      • Once all screws are removed, lift the battery out from the base of the computer.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 2 persone hanno completato questa guida.
1Commento della guida
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 58
Tutti i Tempi: 2,787
