Salta al contenuto principale
ACER Aspire 7750G-6645 Optical Drive Replacement
Shania Webb
Shania Webb e 2 altri collaboratori
Ultimo aggiornamento il January 8, 2020
4 - 5 minuti
Facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
This is a guide for replacing the optical drive in an ACER Aspire 7750G-6645 laptop.
Are you experiencing :
  • Strange noises such as clicking or humming from the drive.
  • Repeated program crashes or disk errors.
  • Frequent error messages while running software
These are clear indications that the optical drive is in failure mode. This guide entails directions on how to remove an optical drive from this device in order to replace with a new drive. Good luck!
Cosa ti serve
Strumenti
  1. ACER Aspire 7750G-6645 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 3 ACER Aspire 7750G-6645 Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 3 ACER Aspire 7750G-6645 Optical Drive Replacement, Optical Drive: passo 1, immagine 3 di 3
    • Remove the three 2.5mm Phillips #0 screws from the back of the laptop.
    • Remove the back cover.
  2. ACER Aspire 7750G-6645 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Push the orange lock to the left to unlock the battery.
    • The battery should pop up out of place.
    • Remove the battery.
  3. ACER Aspire 7750G-6645 Optical Drive Replacement: passo 3, immagine 1 di 2 ACER Aspire 7750G-6645 Optical Drive Replacement: passo 3, immagine 2 di 2
    • The optical drive is on the right side.
    • Remove the optical drive.
Conclusione
Shania Webb
Membro da: 11/12/19
250 Reputazione
2 Guide realizzate
IUPUI, Team S2-G3, Harley Fall 2019 Membro di IUPUI, Team S2-G3, Harley Fall 2019
IUPUI-HARLEY-F19S2G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 254
