Salta al contenuto principale
A Jammed SD Card Tray
Sqwerks
Sqwerks e 2 altri collaboratori
Ultimo aggiornamento il 23 set 2024
1 - 3 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This is for owners of the 3ds system that have a jammed sd port instead of disassembling the system you can just pop it open in just three steps.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, immagine 1 di 2 A Jammed SD Card Tray, A Jammed SD Card Tray: passo 1, immagine 2 di 2
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: passo 2, immagine 1 di 2 A Jammed SD Card Tray, Popping up tray: passo 2, immagine 2 di 2
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: passo 3, immagine 1 di 3 A Jammed SD Card Tray, Popping open tray: passo 3, immagine 2 di 3 A Jammed SD Card Tray, Popping open tray: passo 3, immagine 3 di 3
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: passo 4, immagine 1 di 3 A Jammed SD Card Tray, Remove sd card: passo 4, immagine 2 di 3 A Jammed SD Card Tray, Remove sd card: passo 4, immagine 3 di 3
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
Conclusione
Thanks and you’re welcome now you have free access to your sd card!
Preparati per le riparazioni future
Acquista tutti
Sqwerks
Membro da: 10/31/22
563 Reputazione
1 Guida realizzata
The Sqwerks repair team Membro di The Sqwerks repair team
Community
1 Membro
2 Guide realizzate
4Commenti sulla guida
My first guide 😂
Sqwerks - Replica
its been officially accepted as of two months ago yahoo
Sqwerks - Replica
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - Replica
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,187
