Salta al contenuto principale
8BitDo Ultimate Wireless Joystick Cover Replacement
Cosa ti serve
  1. 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: passo 1, immagine 1 di 2 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: passo 1, immagine 2 di 2
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Chiedi a FixBot
    Aggiungi Commento
  2. 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 2, immagine 1 di 2 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 2, immagine 2 di 2
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Chiedi a FixBot
    Aggiungi Commento
  3. 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 3, immagine 1 di 3 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 3, immagine 2 di 3 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 3, immagine 3 di 3
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  4. 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 4, immagine 1 di 3 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 4, immagine 2 di 3 8BitDo Ultimate Wireless Joystick Cover Replacement: passo 4, immagine 3 di 3
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  5. 8BitDo Ultimate Wireless Joystick Cover Replacement, Joystick Covers: passo 5, immagine 1 di 1
    • Grip each joystick cap firmly and pull straight up to remove them.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 63
Tutti i Tempi: 138
