Salta al contenuto principale
360fly 4K SD Card Replacement
Jacob Herron
Jacob Herron e 3 altri collaboratori
Ultimo aggiornamento il December 20, 2021
8 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
This guide walks you through how to replace the SD memory card on a 360fly 4K camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. 360fly 4K SD Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K SD Card Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K SD Card Replacement: passo 3, immagine 1 di 2 360fly 4K SD Card Replacement: passo 3, immagine 2 di 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K SD Card Replacement: passo 4, immagine 1 di 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K SD Card Replacement: passo 5, immagine 1 di 2 360fly 4K SD Card Replacement: passo 5, immagine 2 di 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K SD Card Replacement: passo 6, immagine 1 di 3 360fly 4K SD Card Replacement: passo 6, immagine 2 di 3 360fly 4K SD Card Replacement: passo 6, immagine 3 di 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K SD Card Replacement, SD Card: passo 7, immagine 1 di 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K SD Card Replacement: passo 8, immagine 1 di 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K SD Card Replacement: passo 9, immagine 1 di 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K SD Card Replacement: passo 10, immagine 1 di 1
    • Press and release the SD card to remove it from the circuit assembly.
Conclusione
Altre 5 persone hanno completato questa guida.
Jacob Herron
Membro da: 11/08/17
463 Reputazione
3 Guide realizzate
IUPUI, Team S5-G3, Baechle Fall 2017 Membro di IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Membri
3 Guide realizzate
Un commento
Really useful guide, thanks
John Erikson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,180
