Salta al contenuto principale
360fly 4K Battery Replacement
Jacob Herron
Jacob Herron e 5 altri collaboratori
Ultimo aggiornamento il December 20, 2021
25 minuti
Moderato
Guida Studente in Evidenza
Introduzione Migliore
Introduzione
Vai al passo 1
This page will guide you on the replacement of the battery on your 360fly 4K camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. 360fly 4K Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Battery Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
    In the older model for Fly360 camera, the screws are PH000.
    Renjamin - Replica
    In the old 360Fly HD camera, the screw requires a #00 Philips head screwdriver. Unfortunately for me, one of the screws on mine was torqued down a bit too tight, that I ended up stripping the screw head trying to loosen it by hand.
    XzTS - Replica
  3. 360fly 4K Battery Replacement: passo 3, immagine 1 di 2 360fly 4K Battery Replacement: passo 3, immagine 2 di 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Battery Replacement: passo 4, immagine 1 di 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Battery Replacement: passo 5, immagine 1 di 2 360fly 4K Battery Replacement: passo 5, immagine 2 di 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Battery Replacement: passo 6, immagine 1 di 3 360fly 4K Battery Replacement: passo 6, immagine 2 di 3 360fly 4K Battery Replacement: passo 6, immagine 3 di 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Do I have to remove the battery to replace the SD card?
    BoB - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Jacob Herron
Membro da: 11/08/17
463 Reputazione
3 Guide realizzate
IUPUI, Team S5-G3, Baechle Fall 2017 Membro di IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Membri
3 Guide realizzate
5 Commenti
Wich one battery Can I use to replace It?
Marco Pereira - Replica
Where can i purchase a battery
john hernandez - Replica
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Replica
Battery part number?
R H. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,726
