Salta al contenuto principale
2017 Kia Niro Headlight Replacement
Sydney Harper
Sydney Harper e 4 altri collaboratori
Ultimo aggiornamento il July 10, 2022
10 - 25 minuti
Facile
Introduzione
Vai al passo 1
This guide gives step-by-step instructions to replace the XtraVision Fog Light/Headlight Bulb 9005XV-2 in a 2017 Kia Niro. Fog Light/Headlight bulb usually burns out after 1000 hours and it needs to be replaced but some others last for 30000 hours. When replacing Fog Light/Headlight Bulb 9005XV-2 in a 2017 Kia Niro, Fog Light/Headlight Bulb should be changed in pairs. For safety concerns, Bulbs should be changed before they burned out because driving without functioning bulbs can be dangerous at night.
  1. 2017 Kia Niro Headlight Replacement, Headlight: passo 1, immagine 1 di 1
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: passo 2, immagine 1 di 1
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: passo 3, immagine 1 di 1
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: passo 4, immagine 1 di 1
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: passo 5, immagine 1 di 1
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: passo 6, immagine 1 di 1
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: passo 7, immagine 1 di 1
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: passo 8, immagine 1 di 1
    • Reattach the cap you previously set aside by rotating clockwise until secure.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Sydney Harper
Membro da: 10/23/20
229 Reputazione
1 Guida realizzata
Texas Tech, Team S9-G6, Cowan Fall 2020 Membro di Texas Tech, Team S9-G6, Cowan Fall 2020
TTU-COWAN-F20S9G6
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 110
Tutti i Tempi: 4,962
