Salta al contenuto principale
2012 Nissan Murano Driver Side Mirror Replacement
Gajtguy
Gajtguy e 3 altri collaboratori
Ultimo aggiornamento il July 12, 2017
45 minuti
Facile
Foto Azione
Necessarie Immagini Migliori
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Full replacement of a Driver side mirror on a 2012 Nissan Murano, SL options package.
  1. 2012 Nissan Murano Driver Side Mirror Replacement, 2012 Nissan Murano Driver Side Mirror: passo 1, immagine 1 di 1
    • Pull out the Driver preset panel, if your options package included this. Usually no tools required.
  2. 2012 Nissan Murano Driver Side Mirror Replacement: passo 2, immagine 1 di 1
    • Expose one of three screws by prying the door handle trim plate out.
  3. 2012 Nissan Murano Driver Side Mirror Replacement: passo 3, immagine 1 di 3 2012 Nissan Murano Driver Side Mirror Replacement: passo 3, immagine 2 di 3 2012 Nissan Murano Driver Side Mirror Replacement: passo 3, immagine 3 di 3
    • Pry out the door lock and window control panel. Disconnect all connectors on the back side.
  4. 2012 Nissan Murano Driver Side Mirror Replacement: passo 4, immagine 1 di 1
    • Pry up the arm rest to expose the second hidden screw (total of 3).
  5. 2012 Nissan Murano Driver Side Mirror Replacement: passo 5, immagine 1 di 1
    • Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now the door panel itself can be pried off the door. Starting at the bottom, find the plastic friction plugs and pull enough to pop them out one by one.
    • Then lift the door panel up off the door. You do not need to remove it completly. This should give you enough room to work on the mirror in the next steps.
  6. 2012 Nissan Murano Driver Side Mirror Replacement: passo 7, immagine 1 di 2 2012 Nissan Murano Driver Side Mirror Replacement: passo 7, immagine 2 di 2
    • Pull the inside mirror cover off.
  7. 2012 Nissan Murano Driver Side Mirror Replacement: passo 8, immagine 1 di 1
    • Unplug the mirror wiring harness. The connector on the door will stay put.
  8. 2012 Nissan Murano Driver Side Mirror Replacement: passo 9, immagine 1 di 1
    • Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
Conclusione
Altre 3 persone hanno completato questa guida.
Gajtguy
Membro da: 12/15/13
177 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 23
Tutti i Tempi: 6,988
