Salta al contenuto principale
2008 Toyota Corolla Battery Replacement
Lair Noriega
Lair Noriega e un altro collaboratore
Ultimo aggiornamento il March 18, 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to replace the battery in a 2008 Toyota Corolla. To get started, ensure the vehicle is parked in a safe place and turned off. Place the vehicle in park and engage the parking brake. Be sure to prepare baking soda mixed with water to clean the terminals.
  1. 2008 Toyota Corolla Battery Replacement, Battery: passo 1, immagine 1 di 2 2008 Toyota Corolla Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: passo 2, immagine 1 di 2 2008 Toyota Corolla Battery Replacement: passo 2, immagine 2 di 2
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: passo 3, immagine 1 di 2 2008 Toyota Corolla Battery Replacement: passo 3, immagine 2 di 2
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: passo 4, immagine 1 di 3 2008 Toyota Corolla Battery Replacement: passo 4, immagine 2 di 3 2008 Toyota Corolla Battery Replacement: passo 4, immagine 3 di 3
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: passo 5, immagine 1 di 3 2008 Toyota Corolla Battery Replacement: passo 5, immagine 2 di 3 2008 Toyota Corolla Battery Replacement: passo 5, immagine 3 di 3
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: passo 6, immagine 1 di 1
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Lair Noriega
Membro da: 04/04/22
237 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 245
Tutti i Tempi: 5,321
